| lunger |
Jul 10, 2011 12:56 PM |
high suction pressure with low discharge pressure
I changed my compressor out after hearing the pulley bearing grinding a bit. However when I serviced the system my low side pressure was 110 and the high side pressure was 200. I recovered the system and changed the expansion valve thinking it was clogged but after re-servicing I'm still getting the same numbers. The compressor is running with clutch engaged but there is no noticeable change at the vents.I'm wondering if the compressor I got has bad valves in it or a clogged low side line. Anyone with any possible solution would be greatly appreciated.
Oh I changed compressor or due to my puller distorted the pulley taking it off and now it will hit the field coil so I spent the extra few bucks over a clutch rebuild kit and got a new compressor.
