HIGH TEMPERATURES
Old Dec 6, 2005 | 02:45 PM
kennyhuang02's Avatar
Default HIGH TEMPERATURES
I have a ’95 Honda Civic, it has 60,000 miles. Now I have an overheating problem, because the temperature gauge shows higher than normal readings. I hooked up a water temperature gauge which shows the water temperature is up to 180 degrees and the cooling fan kicks on. When the fan kicks on, the temperature gauge stays the same at a higher than normal temperature, but the water gauge drops. I think it might be either a gauge problem, a water pump problem, temperature sensor problem, or thermostat problem. I don’t know where I should start, can somebody help me? Thanks.
Old Dec 6, 2005 | 04:24 PM
ngoti 8tor's Avatar
Default RE: HIGH TEMPERATURES
Do you have lots of coolant in the system? I would start with changing the thermostat, because it never hurts to have a new thermostat, and it's fairly cheap.
Old Dec 6, 2005 | 07:30 PM
Street Sniper's Avatar
I would gander to say it was the thermostat like negoti8tor said. Start there- they are only like 5 or 10 bucks. If that's not it then we can move on to something else.
rad151
Apr 22, 2009 02:18 PM
dmsteele92831
Oct 7, 2006 11:21 AM
liliechen
Dec 25, 2005 11:15 AM
triggerstep
Dec 16, 2004 12:00 PM
flagcivic
Oct 16, 2004 09:55 AM
