How to change clutch
I have a 94 ex with a b18, I need to replace the clutch what’s the proper way to do it?? |
Raise front end of vehicle
Remove lower splash shield, and front wheels Remove/unplug VSS, starter, reverse solenoid, slave cylinder Drain transmission Remove axles Unbolt transmission mount while supporting rest of the engine Remove transmission, pressure plate, clutch, and flywheel (optional) Reinstall everything. You may need to remove the passenger side axle to give you more room. Crack the axle nut loose before you raise the vehicle if you plan on doing that. |
