How to change clutch
Raise front end of vehicle
Remove lower splash shield, and front wheels
Remove/unplug VSS, starter, reverse solenoid, slave cylinder
Drain transmission
Remove axles
Unbolt transmission mount while supporting rest of the engine
Remove transmission, pressure plate, clutch, and flywheel (optional)
Reinstall everything.
You may need to remove the passenger side axle to give you more room. Crack the axle nut loose before you raise the vehicle if you plan on doing that.
Drain transmission
Remove axles
josephdstone
16
Dec 14, 2009 10:01 AM
digimon916
Sep 22, 2007 08:05 AM
