How do I get rid of squeaky clutch(when I press in or release)
Old Apr 13, 2008 | 07:01 AM
inthezoneac's Avatar
Default How do I get rid of squeaky clutch(when I press in or release)
sometimes on dry days when I press or release my clutch pedal it makes a squeaky noise everytime. It's not super loud, but it's there and very annoying. Anyone else have this problem, and is there an easy way to fix it?
Old Apr 13, 2008 | 07:23 AM
Default RE: How do I get rid of squeaky clutch(when I press in or release)
I also hear a similar clutch pedal squeak sometimes. Not sure but it may be coming from an area around the slave cylinder. I'll be interested to know if there is an easy fix.
Old Apr 13, 2008 | 08:05 AM
mine squiked alittle when i got it... i just sprayed the pedal pivot points with some WD40 and i havent heard it make any more noise since...
Old Oct 16, 2008 | 05:58 AM
bumping an old thread, not sure that's bad or not.
Today I sprayed the pedal pivot points and pulled back some rubber boot to the left of my header. I did not spray inside the tranny(assuming that's the transmission)/casing, but sprayed where the little rubber boot was at, where the line runs outside.
still squeaking. Do I need to get under the car and spray something else or what?
well I just went back, removed the two bolts holding the master cylinder(correct me if I'm wrong), took out the ball joint cleaned that and the arm it comes in contact with. Squeak gone. I used lithium spray grease.
Old Oct 16, 2008 | 06:11 AM
Look here:
https://www.hondacivicforum.com/foru...ruction+clutch
Old Oct 16, 2008 | 08:30 PM
^yea i was just about to mention that
yea i did that whatever day i said in the thread, and it hasn't squeaked since.
WhiteRabbit1021
Jul 15, 2007 09:33 PM
dooka4u4
Aug 4, 2006 08:05 AM
dooka4u4
Jul 18, 2006 02:51 PM
Spartan21
Oct 14, 2005 06:50 PM
