Crunchy/Squeaky Clutch Noise
Old Jul 18, 2006 | 02:52 PM
dooka4u4's Avatar
Default Crunchy/Squeaky Clutch Noise
When I move my clutch up and down, depending on the weather and how much I used the car recently, it will have a crunchy feeling/squeak sound to it. I notice this on very humid days or right after it rains… and I get in the car after it has sat for a bit.
With the engine running the clutch feels crunchy/squeaks only when I press it up or down. If I hold it down with the engine running, it doesn’t make a sound – leading me to believe it is not a throw out bearing. Nor does the car make any squeaks when the clutch is up.
The sound is definitely outside the car… possibly coming from the engine bay near the transmission. Is there a spring or anything associated with the slave cylinder?
I know that my clutch master cylinder needs replaced because it does drip a bit of fluid occasionally inside the cabin.
How hard is it to replace the clutch master cylinder/slave cylinder. I figure I’ll buy a kit that has both (close to the same price as the master alone).
Any help would be greatly appreciated,
Jim
Old Jul 18, 2006 | 06:34 PM
civicexracer's Avatar
Default RE: Crunchy/Squeaky Clutch Noise
if its a squeaky kinda sound when u push the clutch pedal in, then it seems to be a very common thing and somthing that dosnt really matter to much. mine does that allllll the time, has been doing so for a long time and it's never given me any kinda troubles but just being annoying from the sound. my dad told me its prolly some spring, tho i dont know what or where this spring is, kinda beginning to think there is no spring but i dunno.
Old Jul 18, 2006 | 11:57 PM
baker's Avatar
mine and all of my friend's civics do that.
Old Jul 19, 2006 | 12:07 AM
Mr Mobsta Man's Avatar
Mine squeeks when the engine is still cold but after its been on for a few mins. it doesn't do it anymore.
Old Jul 19, 2006 | 01:51 AM
neon3kgt's Avatar
mines been doin it for 15k miles sence i got it... id say its the rubber cup seal in the slave cylender.
Old Jul 20, 2006 | 07:08 AM
dooka4u4's Avatar
Thanks for your replies... Does anyone know how difficult it is to replace the master/slave cylinder? I have to replace the master soon before it starts leaking anymore than it already does. I figure the kit for both is not much more so I could just replace both.
Old Jul 29, 2006 | 01:39 PM
civic_ex_98's Avatar
My Civic only does it when the engine / tranny is still cold - so maybe first 10 mins of driving (depending on temp).. I have 90K on my Civic; my friends' has 130+ and does the same thing.. He never replaced his clutch.
So yes it's an alarming sound, but maybe not that big of a deal really.
Old Jul 30, 2006 | 09:13 PM
fglaustin's Avatar
i dont think i would do both unless i had to.
did one on a toyota and it was one bear of a job.
have to get down on the gound and work up under the dash.
and then the bleeding part - took a lot of time
Old Aug 1, 2006 | 04:54 PM
dooka4u4's Avatar
Does anyone know if there are any springs or whatnot connected to the slave cylinder that could be causing the squeaking?
It has to be something open to the elements since it doesn't happen unless it is relatively humid out or has rained since the last time I used the car.
Old Aug 1, 2006 | 10:22 PM
jrhaupt1's Avatar
More than the slave cylinder, it could be the lever arm that presses on the throwout bearing.
