how do I install spark plug wires
Old May 19, 2007 | 02:37 PM
Zach_17's Avatar
Default how do I install spark plug wires
If someone could let me know how to install new spark plug wire I would appreciate it
Thanx
Old May 19, 2007 | 03:46 PM
hatch46580's Avatar
Default RE: how do I install spark plug wires
very simple, when you get your new wiers there will be 4 in a box. each wire is a different lenth, start with th longest wire and remove it from your car, just pull up it might be a little tight , then remove the end on your desributor, now find the longest wire in your new wires and place it back in to the engine. then from there on just go down in the sizes.
good luck and come back if you need more help and like alsways.
[sm=welcomesign.gif]to HCF
Old May 19, 2007 | 04:14 PM
also best to do one wire at a time.... that way you dont mess up the firing order.
very easy!
Old May 25, 2007 | 02:56 PM
Tim706's Avatar
Excellent idea to do it one at a time. But one other thing, there is a fifth wire in the box, from the coil to the distributor, don't forgot to replace that too, it will look different from all the other wires, it won't have a long boot on the end.
Oh, and when you install the wires, make sure you push down firmly until you hear/feel a slight click, then give the wire a slight tug to make sure it is seated securely.
skytanker2003
Jul 19, 2005 08:12 AM
smokingemcee
May 17, 2005 08:15 PM
fast93civic
Feb 5, 2005 04:47 PM
bulletman0_0
Nov 8, 2004 11:17 PM
civic1.5uk
Jul 24, 2004 03:15 PM
