How do I swap my rear tailights? 2008 Civic Coupe
Old Jul 30, 2008 | 06:09 PM
Apostle's Avatar
Default How do I swap my rear tailights? 2008 Civic Coupe
Hey,
I am trying to install my new tail lights. I unscrewed the lights from inside the trunk, but there is still something holding it in. Seems to be on the bottom of the light. Do I have to take off the bumper to finish this job? If so. How do I take off the bumper? Any advice would be great. Thanks.
Sorry if this has been covered. I've been searching the forum and havn't been able to find anything helpful. Thanks in advance.
Old Aug 1, 2008 | 11:45 AM
Apostle's Avatar
Well, I figured it all out myself. You do have to take the bumpr off. I posted a how to in the DIY section for anyone else that is going to do this job. Also, here is what I posted.
Hello,
I spent too much time changing my tail light fixtures on my 08 coupe this past weekend. I could find nothing online to help me, so I struggled through it. I hope this saves others some time.
This is annoying but you ARE going to have to take off the bumper to do this. (ridiculous I know, but it's a must)
1) If you have the mud guards behing the back wheels, you need to take those off. There should be 3 phillips head screws. This part is no problem. And while you have them off. Take a few minutes to clean them. It's a rare chance to give them a good cleaning.
2) There are 2 screws in each wheel well holding the bumper to the car. One is right above the top screw on the mud guard, or about half we up the wheel well, right on the outside edge. The other screw is screwed upwards at the top back edge of the wheel well.
3) Under the back of the car there are 2 plugs holding the bumper to the plastic under carriage thing. Use a flat head screw driver to pop them out, then they just basically fall out.
4) Now you can start un clipping the bumper. All along the top seam there are clips. You kinda have to force it. But it pops out pretty easily.
5) Last there are 2 allen wrench screws on either either side of the trunk opening. Those are the last things holding the bumper on. Now the bumper comes off and be careful, it's flimsy and fragile.
6) Now you can see why you needed to take the bumper off. The tail lights are screwed onto flanges that attach to the car. Unscrew the 2 bolts on each on that connect it to the car. And unscrew the flange from the tail light fixture.
7) Inside the trunk you need to peel back the wall of the trunk. There are 3 plastic flat head screws on each side of the trunk. Take them off and then the cover just peels back.
8) Un plug the wires and there are 4 bolts securing the fixture to the car. Unscrew those and the light fixture comes off very easiliy.
9) Swap your bulbs.(Note that one of my bulbs is basically impossible to change with the fixture on the car. So put the bulbs in before you put the new fixture on, just to be safe.)
10) Put the new tail lights on in reverse order. Make sure the fixture lines up with the car body properly. The flange that attaches to the car can slide side to side. So manuever until the lights are flush, then tighten it down. Otherwise you'll have the tips of the lights protruding from the side of the car. (very ricy)
11) If you got LED tail lights like I did. the wiring probably isn't correct. My new lights had 2 black, 1 green and 1 red wire. the car had 1 green, one red, and one black. To get them to work properly, I attached the green light wire, to the cars red wire. The cars green wire, to the light fixtures red wire. And one of the black to the black. The extra black wire i just taped off. (Also, if you happen to blow a fuse(which I did on accident) it is a 7.5 amp fuse in slot #26 under the dash, the backup to that is a 10 amp in slot 30)
14) The bumper goes on very easily. Just pop it back on and put the screws in.
I think I included everything that tripped me up. Hopefully this saved you some time.
Feel free to PM me for advice. I would be glad to help anybody out.
LamboCivic
Apr 20, 2006 08:53 PM
Kahuna
Mar 15, 2006 11:13 AM
rayj05
Feb 14, 2006 03:21 PM
93AccordCoupeSE
Jan 18, 2006 09:13 AM
