How do u test a fan switch?
I have a 95 Civic LX w/ some heating issues. The troubleshooting flowchart in the manual tells me to test continuity btwn terminals on my fan switch. Am I supposed to test continuity btwn 3 terminals? If so...how?
Thanks
______________________________________________
WTB:
1995 Honda Civic LX parts:
Fan Switch...if mine is bad (see post)
Center panel
Projector Headlamps/Taillights
PM me
Thanks
WTB:
Center panel
PM me
Also, the lowest I've seen the switch is around $15. I haven't really looked that hard. I've already spent too much this month on the car. I was wondering...since a switch is pretty basic (a device to make a connection), Can I repair it?
You test one circuit at a time. For example in position 1 there should be continuity between 1 and 4 as well as 1 and 6. (and 4 and 6, but you don't really need to test that).
Typically when the fan doesn't work on high but does on other speeds, the switch is bad (since the position 4 circuit handles more current it is prone to burn out). If the fan works on high but not other speeds the resistor is probably bad.
That's the way I thought I should do it (test two terminals at a time). OK, so the switch is bad. I wasn't hearing beepis on any combination. That's why I wasn't sure I was doing it right.
What do u think about my other question. Can I repair the switch? I was thinking of opening it up & making sure each connection would work as planned.
Fixed the fan switch. Got continuity like in the manual.
_______________________________________________
WTB:
1995 Civic LX parts:
Center panel
Aftermarket headlamp/taillight assemblies (projector, halo, something cool?)
Center caps
PM me
WTB:
Center panel
Center caps
PM me
If they all share one post (wire plug) that one will usually be a common (ground) so like mk said you would just check from there. I just suggested replacement because that is usually a lot easier than trying to repair or worry about a switch, once it is worn it is worn unless you just had a break in a wire. Glad to see you got it working though, bro.
anivast999
May 14, 2011 06:15 PM
