How to fix door lock?
Old Feb 21, 2008 | 03:52 PM
Civic_TX's Avatar
Default How to fix door lock?
I've had this problem for a while,but now want to get it fixed.My driver side door will not lock when I use the power switch,only my passenger side locks.Civic 2000 ex,any help thanks
Old Feb 21, 2008 | 04:40 PM
Default RE: How to fix door lock?
Most likely a bad lock actuator in the driver's door. Definitely a DIY. You'll need to take the trim off the door.
Old Feb 21, 2008 | 05:14 PM
jpnolan's Avatar
if you dont want to fix it like me just hold the inner door handle open and press down the lock
Old Feb 21, 2008 | 06:33 PM
bakertime's Avatar
I've heard it's a bit of a pain to replace the acuator, but you'll save some money for sure. I had a shop do mine when it went in my 01
Old Feb 21, 2008 | 06:57 PM
Civic_TX's Avatar
Thanks everyone,might try it myself
Old Feb 21, 2008 | 07:38 PM
ORIGINAL: Civic_TX
...might try it myself
Old Feb 21, 2008 | 08:24 PM
mud's Avatar
mud
I don't believe the driver door is supposed to locked when you press the switch, only the passenger. It's a kind of safety so you don't lock yourself out. In order to lock thedriver's without the keyless entry you have to hold the handle open then push the button. I've had two 2000 exs that both did this and my brother's 95 dx also had to have the handle open to manually lock it.
mrossi22
Feb 4, 2015 10:28 AM
redraif
Mar 7, 2013 01:59 PM
ghostbusters101
Dec 15, 2010 07:32 PM
Koala
Oct 12, 2007 09:38 PM
s2000gtx
Jun 21, 2007 07:39 AM
