how long can i run on 3 cylinders
Old Jan 12, 2014 | 07:09 PM
grove's Avatar
Default how long can i run on 3 cylinders
98 civic ex, #4 cylinder has 60 psi. Its my only car. Right now im getting crappy mileage obviously. Can i unplug the fuel injector and spark plug wire and run it like that? How long can i run it like that? I drive 100 miles a day. Im not able to fix the problem anytime soon. Hopefully this coming weekend depending if its the head or rings. Which ill find that out in a couple of days.
Old Jan 12, 2014 | 07:42 PM
Check your valve adjustment before concluding the engine is shot. A valve that is too tight will leak compression.
Also you're probably getting some power from that cylinder, though it may not fire at idle at higher rpm you build more pressure.
Don't disconnect the spark plug wire. There's no harm in letting the spark plug continue to fire. Do disconnect the injector to prevent wasting gas and flooding the cat converter with raw gas, which will burn it up.
Old Jan 12, 2014 | 07:48 PM
grove's Avatar
Ive checked the valve adjustment. Its within specs. Hell i moved it to loosest side of the spec just to see if my compression would come back. No joy. Intake valves sittin at .009 and exhaust is now .011 befor that the intake sat at .007 and the exhaust was at .009
samilitant
Jan 8, 2007 10:47 PM
ScoobyAddict14
Sep 30, 2006 08:02 PM
Remmy
Mar 6, 2005 01:18 PM
RiceBurner
Feb 6, 2005 04:40 PM
RiceBurner
Jan 16, 2005 09:09 PM
