How much do you think these repairs will total
Old Apr 3, 2009 | 07:01 PM
yung-dilla's Avatar
Default How much do you think these repairs will total
iight i know it's not gonna be an exact estimate but just look for some ball park figures
1. heat doesn't work idk why
2. need a new ac hose
3. power lock switch doesn't work (power windows do work)
4. back window defrost doesn't work
5. dash lights got a minor shortage sometimes the dash won't light up and that sucks while driving on the highway lol
6. sometimes i'll push on the gas and it just won't accelerate you hear like it's trying to push power out but it doesn't i have to take my foot off the gas and then damn near floor it?????????????
7. sometimes when i brake or accelerate the car jerks idk what could this be?????????????
8. the first power setting of my wipers don't work but the medium and fast settings work fine?????????
Old Apr 3, 2009 | 07:19 PM
Can't give cost estimates until you pinpoint the problems.
What year Civic? Does the blower work? Is the coolant level low? If not, check whether the heater valve on the firewall is not moving when the heater lever is pushed.
Which hose?
Check for blown fuses.
Possible dimmer switch problem.
When did you last replace the plugs, wires, cap, and rotor?
Possible bad wiper motor or switch.
Old Apr 3, 2009 | 07:28 PM
yung-dilla's Avatar
[QUOTE=yung-dilla;634044]
it's a 93 civic timing belt,water pump,plugs, filters,drive belts,and new tires all replaced beginning of last month got the papers when i bought the car then, blower barley works it blows but doesn't have alot of power behind it matter of fact can barley feel the air blowing out air conditioning hose (that's what they guy at auto zone called it) cap and rotors not sure but my friend said they need to be cut (idk)
Old Apr 3, 2009 | 07:31 PM
Inspect the distributor cap and rotor and check the ignition timing with a timing gun. When were the plug wires last replaced?
Old Apr 3, 2009 | 07:39 PM
yung-dilla's Avatar
not sure if the guy i bought it from changed the plug wires or just the plugs i know the plugs were done last month not sure if he changed the wires
Old Apr 3, 2009 | 07:45 PM
You can check the resistance of the wires with a multimeter.
Old Apr 3, 2009 | 07:47 PM
yung-dilla's Avatar
ok thanks and i'm thinking about replacing the rotors all together because they are rusty, i'll go down to auto zone and have them test the wires since i don't have a multimeter.
Old Apr 3, 2009 | 07:53 PM
no no no he means the rotor in the distributor not the brake rotors. lol
Old Apr 3, 2009 | 07:57 PM
yung-dilla's Avatar
ohhhhhhhh still don't know but i'll get back at you guys tomorrow when i find everything out still since my brake rotors are rusting should i just replace them?
Old Apr 3, 2009 | 07:58 PM
The brake rotors rust under normal conditions unless they are zinc coated.
I think you should just go to a mechanic with all these problems instead of fixing yourself.
