how to remove rear seat in '97 sedan?
Old Aug 9, 2009 | 10:02 AM
wkhan69's Avatar
Default how to remove rear seat in '97 sedan?
Hi all,
In an attempt to fix my "floating around" fuel gauge problem (97 civic sedan, 1.6l), I am trying to replace my fuel sending (metering) unit. I looked in the Haynes manual on how to go about doing this, and some steps were unclear. This is probably very basic, but I could use some guidance:
My goal is to remove the fuel metering unit. The Haynes manual says to remove the rear seat first.
  1. Do I remove the rear back rest (vertical part) of the seat, or the rear horizontal part, or both?
  2. How do I do the above? Do I need to pull the carpet anywhere? (step by step would be awesome. The Hayne's manual's pictures are not obvious).
  3. If I remove the rear seat, will the fuel metering unit access plate be obvious to get at?
  4. I would like to do this on a budget. Would anyone recommend that I get a used fuel metering unit from the wreckers, or is this a definite no-no?
Many thanks!!
Will
Old Aug 9, 2009 | 10:21 AM
your fuel pump and everything is under the bottom back seat..
the is one 10mm bolt that holds it in.. stick your hands inbetween the seats where middle seat belt comes out and you will find the bolt that holds it in. then once bolt is out seats flip up and the out. there is 3 phillip screws that are on the fuel cover then remove the fuel line from tank. and then remove all the bolts that hold the gas tank cover and unplug the wire clip.... the you can pull out the completre fuel pump assembly
here is a howto with pics
http://importnut.net/walbro.htm
Old Aug 9, 2009 | 12:34 PM
wkhan69's Avatar
AWESOME! I will try this. Thanks big time!!!!!
Will
Old Aug 10, 2009 | 06:01 PM
The bottom cushion has hooks holding it down at the front. After pulling it up at the back like 94 said, keep tilting it forward until the hooks release.
You'll probably find enough dropped coins under there to pay for the rest of the job.
Old Aug 10, 2009 | 06:05 PM
i know i did when i removed mine in my sedan also found a nice little real diamond ring.
the change i used at carwash to clean it with
jason_hann53
Dec 15, 2007 01:18 PM
arneycl
Aug 9, 2007 12:59 PM
kennycivicparts
Mar 1, 2007 05:19 PM
F23AccordLX
Jul 16, 2006 01:44 PM
OCH Orange County Honda
Jul 3, 2006 05:40 PM
