hron fuse
Old Mar 30, 2006 | 11:30 PM
patcheway's Avatar
Default hron fuse
anyone know where the horn fuse is on a 88 crx i looked in the chilton manual and everything and can not find it my horn doesn't work and i wanted to try the simpliest thing first.thanks
Old Mar 30, 2006 | 11:40 PM
b8teen's Avatar
Default RE: hron fuse
i believe that the actual horn on your car is near the radiator. everytime my horn hasnt worked, in any of my cars, it has been because of it not actually being plugged in. that being the easiest. you can also check the fuse box in the engine compartment, i believe there is a horn fuse. im not sure if there is a fuse for the horn under the dash, but check to see if there is. last but not least, it could be a problem in your steering wheel. there are little metal terminals that have to make contact, make sure thier doing that. good luck
864DRCivic
Jan 23, 2021 06:19 PM
IMPORTEDCONCEPTZ
Dec 10, 2006 09:46 PM
irate808
Apr 17, 2005 10:40 PM
mitsuman57
Feb 26, 2005 10:04 AM
Magnum
Oct 8, 2004 10:28 AM
