i ned a motor mount for a b16a jdm in a 1994 civic si....what part???
i have a bad upper motor mount on drivers side, it's in a 94 civic si b16a jdm engine, i need to know what part to buy im thinking its a mount for 1994 del sol V-TEC, but not sure....any of you all know this answer?:confused:
Any stock 92-95 Civic mount should work just fine.
ill try that, i hope its right, i don't want to be out $$
thanks ill let you know if its right |
If you look various companies selling mount kits for your vehicle, you will see most all of them stating D/B series mounts. ;)
i have a spare old D16Z6 mount off an old 94 civic EX, ill check if it will work next week when i get over to the shop to get it,,,,,crossing my fingers, so will save me $200.00
thanks!!! |
different mounts????? B and D series mounts are different!!
2 Attachment(s)
here is a picture of the B16A mount i needAttachment 3261, its a 2 bolt, the D16Z6 mount is 3 bolt pictured hereAttachment 3262
i want to order a honda hydro stock mount rather than a aftermarket one, which part number or car has the 2 bolt mount? is it a integra gsr or del sol vtec or another car???:confused: |
That three bolt came from an Integra or B18 motor I would guess. The 99-00 Civic SI has the 2 bolt.
Aren't those the same if you were to leave out the third bolt? You may need to replace the bracket on the engine with one from a Civic.
Originally Posted by mk378
(Post 779453)
, or a 1994 integra vtec, which would work best? or are they the same:) |
I think its either part number 50820-SR3-J11 or 50821-SR3-020
| All times are GMT -8. The time now is 10:32 PM. |
