I need help 95 civic won't start
So I'm new to the whole civic and mechanic area, I recently bought a civic 95 ex 1.6. Anyways so the car ran PERFECT it had no real big issues except it needed the o-ring for the oil not to leak from the distributor. So i decided to do it myself, so i removed the spark plug wires from the distributor cap, removed the distributor. So I Put the o-ring on and once I put everything back to its place and now it cranks but won't start. The firing order is correct. The wires are plugged in correct, the distributor isnt 180° off. but still no start...I need help.
You can't mess up the timing with this distributor, it only goes in one way.
What I was saying in my previous post is when you remove your distributor and you disconnect the distributor harness then when you reinstall, the contact of the harness may not sit correctly or fully connected.
Also, TRIPLE check your firing order.
