I need to replace manual window crank handle and shaft
I have a '96 Civic DX Hatchback with manual windows. Early last year my driver's side window crank became very difficult to turn and finally the handle just broke off leaving just the shaft. For the past year I've been using pliers to turn shaft and now it is completely stripped and mangled. Originally I was going to replace just the handle but now it looks like I will have to replace the whole handle "assembly" including the shaft. The online car parts stores only seem to sell the handle itself and the window regulator, neither of which includes the crank handle shaft. Am I going to have to a whole new door or is there another way? Thanks!
I'm not 100% sure, but I thought that part was included in the whole regulator assembly.
Here's a diagram. Honda Automotive Parts
Thanks for the advice! I was planning on replacing the whole regulator but I didn't realize the shaft came with it. I thought it was connected to the door itself somehow. So that's great that I don't have to buy a whole new door!
I also need to replace both side view mirrors (housing and glass) and the driver's side headlight lens. Are those easy jobs?
Side view mirrors are removed by prying off the triangular trim piece and unscrewing the bolts from inside the car. I don't know about the headlights, on some models the bumper needs to be removed first to reach the bolts that hold the headlight assembly on.
Blackcivic2005
Jan 4, 2010 04:37 PM
