IAC blocked off, need some help! EJ8
Old Apr 12, 2014 | 07:48 PM
paintballer1184's Avatar
Default IAC blocked off, need some help! EJ8
Ok so to make a long story short, I have a 98 ex. Had a CEL got misfire codes, put on a new distributor because my IAC is blocked off and that was my mechanics suggestion. With a new distributor it still idled low. Adjust the fast idle? screw, now the idle is fine but rough until its warm. Thing is I have an IAC, but its blocked off. And as I recall I didn't get the p0505 code before, but now I do. Could I just unplug the battery and reset the ecu so this can go away. I need to get my car inspected! Symptoms are the rough idle until I drive and earlier it was sputtering and shaking, but when I drove it home I was good. This CEL is annoying and so are the misfires!
Old Apr 13, 2014 | 05:03 AM
The following is is assuming it's a manual EX with a two-wire IACV. The automatic has a three wire IACV and I'm not exactly sure how to check it.
When you say blocked off, you're talking about the air side right? The water lines really aren't necessary for operation though they help in extremely cold weather. A lot of people bypass the water side and it will still run properly.
Remove the IACV and try to blow air through the air passages. With no electricity applied, it should be closed. If it is stuck open try cleaning it with carb cleaner.
Then put it back on, unblocked, and see what happens.
Old Apr 13, 2014 | 06:02 AM
its only connected by the wire. no vaccum or anything.
TheGaginator
15
Oct 9, 2013 07:41 PM
drynchristopher
Sep 9, 2013 09:15 AM
4bangersurprize
Feb 15, 2010 05:59 PM
addiction2bass
Mar 10, 2008 11:21 AM
Remmy
May 22, 2005 01:04 PM
