Idling problem...
Today I got off the highway after about a half hour going about 70mph and stopped at a redlight and noticed that my car was idling very strangly. It was pulsating between around 1300 to 1600rpm very quickly. I reved it up a few times and let it go back to idle and the pulsating continued. I turned off the car and restarted it and the problem went away and the car idled normally (around 8-900rpm), as I continued driving the problem happened again... I don't know what is going on, this is the first time this has ever happend to my car... anyone know what's happening???
Bump... car is still doing it. I noticed that if the lights are off it will only do it for a few seconds then slowly go back down to normal idle, could it be electrical??? This problem came out of nowhere and it's really got me stumped, please help...
ya i would def check the idle air controller. mine did the same thing, i heard that if u take off the IACV and clean it with carb cleaner or i even heard simple green cleaner will work on it gets rid of alot of build up inside. make sure its completely dry though before u put it back on i used an air hose from work and blew the crap outa it
