IGNITOR QUESTION
Old Sep 18, 2006 | 08:37 PM
CYNTHIA9973's Avatar
Default IGNITOR QUESTION
FIRST, WHERE IS IT LOCATED? SECOND, HOW CAN IT BE TESTED TO SEE IF IT IS WORKING?
Old Sep 18, 2006 | 08:47 PM
HARI.'s Avatar
Default RE: IGNITOR QUESTION
it's in your distributor. take the cap off and you'll see like 4 wires on it. looks like this:
HOW TO TEST IT:
1. Remove the distributor cap, the distributor rotor, and the inner cover.
2. Disconnect the BLACK/YELLOW, GREEN, YELLOW/GREEN, and BLUE wires from the ICM.
3. Turn the ignition switch ON. Check for voltage between the BLACK/YELLOW wire and chassis ground. There should be battery voltage.
* If there is no battery voltage, check the BLACK/YELLOW wire between the Ignition Coil and the ICM.
* If there is battery voltage, go to step 4.
4. Turn the ignition switch ON. Check for voltage between the GREEN wire and chassis ground. There should be battery voltage.
* If there is no battery voltage, check the:
* Ignition coil.
* GREEN wire between the ignition coil and the ICM.
* If there is battery voltage, go to step 5.
5. Check the YELLOW/GREEN wire between the PGM-IG ECM and the ICM.
6. Check the BLUE wire between the tachometer and the ICM.
7. If all tests are normal, replace the ICM.
Bluesman
Feb 21, 2012 11:19 AM
krisfnbs
Mar 18, 2008 12:13 PM
GAMBOA
14
Nov 23, 2007 01:59 PM
MarcB
Jan 21, 2007 01:21 PM
thakid
Dec 11, 2006 08:49 PM
