Instrument Cluster/Speedo?
Old Jun 5, 2008 | 02:36 PM
RhysCivic's Avatar
Default Instrument Cluster/Speedo?
Hi, will my 1996 civic hatchback still run if I unplug my speedo?
If any one could give me a link to intructions on removing the speedo that would be appreciated.
How much would you say my speedo is worth?
Thanks Rhys
Old Jun 5, 2008 | 02:53 PM
danomatic93's Avatar
June 2010 ROTM
Default RE: Instrument Cluster/Speedo?
Are you talking about your gauge or the sensor?
https://www.hondacivicforum.com/m_56.../tm.htm#563292
Old Jun 5, 2008 | 03:26 PM
SPLAT's Avatar
Are you asking about the Cluster?
If so then yes, all you have to do is unscrew the 2 screws under the top bezel, pull carefully on the bottom because there
are 2 clips. Once the bezel is removed the cluster is held on by 4 screws, 2 on the top and 2 on the bottom, remove the
cluster and unclipthe 3 plugs, the one on the left is a bit of a pain but take your time.
The whole thing should take about 5 min.
tom8765432
Aug 9, 2005 10:39 PM
tupi1971
Jul 9, 2005 01:33 PM
pkfrdh
Mar 18, 2005 04:11 PM
Honda91
Jan 16, 2005 02:05 AM
monty23psk
May 13, 2004 06:00 PM
