issues
Old Jun 4, 2010 | 05:43 PM
9scivic3i's Avatar
Default issues
so i bought a 1993 si last friday, since then the compression had dropped!
1 is at 125, 2 is at 95, 3 is at 116, 4 is at 80.... the whole bottom end has had been done before i bought the car, there are receipts for all of the parts but not build.. the guys dad did the job! what could be the problem... please let me know.. thanks
Old Jun 4, 2010 | 06:01 PM
silver2000civic's Avatar
It sounds like the rings didnt seat right. Maybe he did hone the cylinders right. If that is the case you need to pull the motor back apart and rehone the cylinders and maybe replace the rings.
Old Jun 5, 2010 | 03:22 PM
9scivic3i's Avatar
wouldnt it be burning oil if the rings didnt seat, because its not bouning oil....
Old Jun 6, 2010 | 05:28 AM
Having the valves adjusted too tight will kill compression.
You can see if it's the rings by putting about a teaspoon of oil into the spark plug hole and test compression again. If rings are bad, the oil will temporarily seal them and increase compression. I agree with the others though; it should burn oil like crazy if the rings were that bad.
gillespiecd
Mar 21, 2005 03:48 PM
Mad7s
13
Mar 15, 2005 10:38 PM
Sharpshooter
Jan 6, 2005 07:07 PM
shorty3788
Nov 21, 2004 11:04 PM
daspoint
May 4, 2004 09:24 PM
