Jumping RPM at speed.
Old Mar 5, 2011 | 02:31 PM
PunisherInOKC's Avatar
Default Jumping RPM at speed.
Working on d16a1. Car starts just fine, runs pretty nice at low RPM. But when I hit about 3k rpm, the RPM gauge jumps up and down and the car runs like crap. I just set the timing again today, and everything appears correct. Any ideas of what I should be checking out?
Old Mar 5, 2011 | 02:40 PM
If the tach doesn't correspond to actual engine rpm that means you're getting inconsistent pulses from the ignition. Assuming it's not a major power or ground problem, it could be the ICM or distributor sensors. Also check that the distributor shaft doesn't wobble.
Old Mar 5, 2011 | 02:58 PM
Tach only corresponds to the actual RPM to about 3k.
IMC?
Distributor and all are solid.
Thanks for quick reply.
Old Mar 5, 2011 | 06:41 PM
Greenhatchy's Avatar
Banned
Bymmmmmdf
Old Mar 7, 2011 | 11:00 AM
droopy128's Avatar
check the coil and ignitor unit..
2fastcivic94
Jun 14, 2009 05:36 PM
ninjak24
Apr 5, 2007 09:41 AM
Marty
Feb 16, 2006 10:09 PM
circuitfox
Aug 20, 2005 09:41 PM
Mossy
Jul 16, 2005 01:12 PM
