Just bought a 90' crx engine off Local shop, LIst of parts needed
Old Nov 22, 2004 | 06:11 PM
dalifts's Avatar
Default Just bought a 90' crx engine off Local shop, LIst of parts needed
Hey i have a 89 dx, i got a 90 crx engine im building so i have a reliable motor and that way i can still use the one i have. Now what parts should i replace for a reliable engine? I dont mind tearing it all the way down to the block. Just want reliability. Thanks
Old Nov 23, 2004 | 08:02 AM
no9t9's Avatar
Default RE: Just bought a 90' crx engine off Local shop, LIst of parts needed
if you're gonna tear it down and want a reliable engine, then you might as well replace all the typical wear and tear components, valves, valvesprings, piston rings, etc. Also check the condition of the pistons like if they are pitted, etc. Replace them too if they are bad. Also, while you're in there, I would port and polish too. It isn't hard at all but takes a lot of time to do a good job. Basically, you just removing excess material (flash, etc.) and smoothing out all the surfaces to make it more efficient.
Old Nov 23, 2004 | 11:21 AM
dalifts's Avatar
yea thats what i wasplanning on doing
Old Nov 23, 2004 | 05:54 PM
sacicons's Avatar
look into some pistons out of an 89 integra, the one with the 1.6L dohc D16. i believe they will fit right in. they will bump the compression about half a point, and can be had for a resonable price at Acura. and hey, the rods out of the same motor should bolt in as well. they are good to over 200 WHP, which will be really hard to get out of a sohc.
Old Nov 23, 2004 | 08:11 PM
dalifts's Avatar
Found out its a crx dx motor. It is Ported and polished tho. So what u think it has right now hp that is ??
megafandrew
Oct 20, 2008 06:02 PM
cjprice618
Feb 3, 2007 11:43 AM
p_moto2
May 4, 2006 11:29 PM
campbuds
North East
Jan 30, 2006 08:50 PM
Forty04
Jan 13, 2006 12:30 PM
