Leaking? Help?
This is recent, My front passenger floor is just soaked! There was a puddle this morning near the door. Im not sure what the cause of it is. It manages to stay soaked too. There is this little black box (maybe the condenser?) behind the glovebox that is moist but I dont know the culprit. Any ideas? Because my car smells like a foot because of all the mildew.[:@]
RE: Leaking? Help?
could it be the coolant from the heater-radiator? Check your coolant levels, then follow the coolant hoses that lead into the cabin(right in the passanger side)
RE: Leaking? Help?
Do you have your power wire run through that grommet below the battery?
That is the AC condensation collector thingy. If that line gets pinched it will build up spill under your carpet. Or it may just have been kicked loose. Check that line and let me know. |
RE: Leaking? Help?
been runnin the ac much --if so --ac drain may be clogged
RE: Leaking? Help?
Will do guys. Thanks for the reply. Ive noticed it spread to the back seat too!!!!! I had a good feeling it had to do with the A/C.
RE: Leaking? Help?
ORIGINAL: AOL.COM been runnin the ac much --if so --ac drain may be clogged |
RE: Leaking? Help?
Pull the carpet back, you will see it. It's a rubber hose going right through the middle of the firewall.
RE: Leaking? Help?
That sound very logical. Ill def check there. I just put one of those humidity buckets in my car (those things with white b.b.s that suck up water) to help get all the wetness out. I found where water has been gathering too! What a mess. O well, that bucket will actually save my car for the time being. Ill go look oncew the dillio is a little dryer. Thanks guys , your help means alot.
RE: Leaking? Help?
You could've blown your heater core.
RE: Leaking? Help?
How would the heater core have blown if I was using the ac? Ne ways... Ive been drying off the mats and I put a humidity bucket in the car. Its working so far, ill see what it does in the morning. Ive also sponged out the floor as much as I could. And I havent used the A/C since. THe Leasking or whatever HAS stopped though, I just need to find the culprit. I haent tried Streets advice yet though. Ive been too busy all day fixin up my new sunfish! [sm=happy046.gif]
