Looking into an engine swap.
Old Mar 29, 2009 | 07:50 PM
Tranqz's Avatar
Default Looking into an engine swap.
I drive a 1993 Si, 1.6L sohc Non-VTEC 5-speed. I'm looking at putting a b18a1 from the Integra GS-R in, an I'm wondering what I'll all need to complete this. A friend told me I'd probably need a new ECU and tranny, just looking to get a second opinion. Thanks for your time.
Old Mar 29, 2009 | 09:19 PM
jpnolan's Avatar
Man, you gotta do a ton more research. First a gsr has a b18c, which is 180hp. A ls has a b18a/b which is 130/140 hp. You need alot more than ecu and tranny, you need axels front brakes, motor mounts, wiring harness custom shift linkage. and so much more.
Old Apr 1, 2009 | 08:46 PM
Tranqz's Avatar
Well, i don't have that kinda cash to spend, so i'm looking at just putting the same engine as what I have in, but VTEC, i'm not sure which one that is... any ideas what I would need to do that?
Old Apr 1, 2009 | 08:51 PM
croninc's Avatar
you can just do a mini me swap and put a vtec head in. Much cheaper.
Old Apr 1, 2009 | 08:59 PM
Tranqz's Avatar
Any idea how much that might cost me?
Old Apr 1, 2009 | 09:10 PM
croninc's Avatar
dont quote me on this but im pretty sure its only like $200
Old Apr 1, 2009 | 09:11 PM
Tranqz's Avatar
Sounds fairly reasonable. Do they require too much work to put in? or is it fairly difficult?
Old Apr 1, 2009 | 09:24 PM
croninc's Avatar
[QUOTE=Tranqz;633719]Sounds fairly reasonable. Do they require too much work to put in? or is it fairly difficult?[/QUOTE
look you need to do some research of your own, we can spoon feed you everything you need to know. Use the search button at the top of the page, you will learn a lot from the topics that come up
mtns1234
Sep 2, 2012 08:00 AM
acortez97dx
EK Swaps
Sep 19, 2010 07:47 PM
cntryboy0110
Jun 5, 2010 09:15 AM
hydro_yang
Sep 12, 2009 01:18 PM
Andrey87
Aug 8, 2007 01:20 PM
