Low voltage at fuel pump connector
Car won't start. Got relay and ECM from salvage place. Still won't start. The voltage at the connector to the fuel pump is 9+or- volts.
Fuel pump will start directly from battery. 1990 Honda Civic Wagonvan. Where do I search next? Please help. |
RE: Low voltage at fuel pump connector
What does it do when you turn the ignition? Turns over won't start... nothing at all... There is a thread with multiple possiblities for not starting ... General problems...
other things are pulling from the battery when you are trying to start.
this is a long shot (just not sure), but i would get a test of the battery under load, or if not that then with one of those new battery testers that are out - they have them at autozone and will test for free. i know that the local wal-mart can test under a load; cant think of an auto parts store that does though. |
It will turn over but not start. When the pump is connected (jumpered) to battery it is operational. Testing the voltage with the key on at connectors. I am not that swift at electrical stuff, but learning.
that's not what i wrote - but since you mentioned it, did you not already do that - in your first post you wrote that there is 9 + or - volts at the connector to the pump.
if car starts when you give fuel pump direct battery power ,, you could have a bad main relay or too much resistance, or bad wiring frm relay to pump ..
