malfunction lamp/cylinder misfire 2003 civic lx
Old Dec 28, 2009 | 06:32 AM
giwatcher's Avatar
Default malfunction lamp/cylinder misfire 2003 civic lx
2003 civic lx 1.7L has a malfunction lamp on intermittently. When on there is a rough idle, but not always. When the light is off, there is no performance problem. The code is p0302, indicating cylinder2 is misfiring. 10 months ago, I had the valves redone by the dealer due to no start, no compression. Also replaced plugs, timing belt, water pump. Can this be a fuel or gas cap issue, or would that set an emissions code? Is it damaging to continue driving since the light is intermittent? Any help as to the cause will be appreciated.
halfpower
May 11, 2015 09:47 AM
genewiedenbeck
Oct 23, 2012 09:32 AM
Shams
Apr 16, 2009 06:22 PM
Shams
Apr 16, 2009 06:11 PM
brown_wallstreet
Apr 7, 2008 01:25 PM
