MAP Sensor caused check engine light to go on?
Hi,
I ran into an unexpected problem today that I need help fixing.
I have a Honda Civic 2000 Ex, D series engine, D16Y8 I think?
Anyways, I was planning on doing some work, I was going to do an oil change and install and new fuel filter, but then it started to rain and I didn't get much done.
But when I was working on it, I tried to move the air intake of the way to get more room in front of the fuel filter, to do that, I simply unplugged the MAP sensor, while the battery was disconnected of course.
My problem is that when I started my car after the rain had stopped me, I noticed the check engine light, and my RPM gauge slightly higher than usual. I also put in a new exhaust system about a year ago, so I could hear my engine slightly revving. As of now I do not have an OBD II Scanner, but I do plan on getting one in the future, but for now, I do need somebody's insight.
(Sorry for the long question)
Thank you...
Thank you...
unhook battery to reset ecu, then start it back up to see if it changes, if cel is still on you can get it checked at any part store for free or under the glove box you can jump the blue plug and turn key to on position and count cel flashes to pull codes
Vox1
Oct 14, 2007 12:29 PM
00sithrottle
May 12, 2005 10:25 AM
Forty04
Mar 9, 2005 01:51 PM
red_sleeper
Jan 15, 2005 01:08 AM
