massove electronic failure
Old Aug 22, 2005 | 09:07 PM
barryscivic's Avatar
Default massove electronic failure
a 1988 honda civic dx had its battery grounded while driving and it smoked the dash unit and main fuse relay only check engine light with new dash from an si also when cranking cuz it does crank the bright light and turn singals go on. it has spark . replaces the main fuse relay with another one i had. still the car will not start and the lights will not go on.
Old Aug 22, 2005 | 10:29 PM
sacicons's Avatar
Default RE: massove electronic failure
can you try typing that a little slower? i got a headache trying to make sense of it.[sm=smiley29.gif]
Old Aug 22, 2005 | 11:10 PM
ok i was driving my car and all of a sudden it back fired i look down and my dash was smoking the car stalled and i pulled over. i open the hood see that the battery grounded. then i hear a clicking and notice its the main fuse realy doing it so i replace that and nothign happens. then i put in the 90 si dash cluster that i had and the check engine light coem on adn so does the blinkers and bright light thign comneon in the dash. the car will crank its gettign gas, and gettign spark whats my problem
Old Aug 23, 2005 | 10:17 AM
Ford's Avatar
Old Aug 23, 2005 | 08:32 PM
sacicons's Avatar
first, check all of your fuses and relays. and that includes the big screw-down fuses under the hood.
Old Aug 23, 2005 | 09:10 PM
maddawg's Avatar
HOPE IT'S A FUSE BUDDY GOOD LUCK
Old Aug 23, 2005 | 09:25 PM
LEVIII's Avatar
DO you mean the power wire of the battery was grounded. cause all batteries are grounded
Old Aug 23, 2005 | 09:34 PM
sacicons's Avatar
i think he means the battery bounced or something and grounded the positive terminal.
xyz357
Sep 7, 2006 08:35 AM
nemesis08
Nov 13, 2005 05:25 AM
barryscivic
Aug 22, 2005 09:15 PM
Benny Sim
Jul 25, 2005 10:19 PM
