which master cylinder for rear diwsc swap?
Old Jul 10, 2006 | 09:15 AM
campbuds's Avatar
Default which master cylinder for rear diwsc swap?
I did the rear disc swap and I need a new master cylinder.
Which master cylinder should I get?
I am thinking one from an integra but it needs to bolt right up with no modification
Old Jul 10, 2006 | 09:31 AM
AgentofDarkness's Avatar
Default RE: which master cylinder for rear diwsc swap?
You will need the brake booster and master cylinder from an Integra
Old Jul 10, 2006 | 09:35 AM
campbuds's Avatar
What year integra?
Will it bolt up to the brake lines or do they need changed?
Old Jul 10, 2006 | 09:40 AM
I would guess that the brake lines should all be the same regardless if what year car you have. What year integra did you get the brakes off? You will also have to change the porportioning valve otherwise it won't work.
Old Jul 10, 2006 | 09:43 AM
campbuds's Avatar
The rear disc conversion is off of a 93 integra... i just haven't upgraded the brake booster or master cylinder yet.
The reason I asked in the first place is because I have no brakes right now. (except for the e-brake)
Old Jul 10, 2006 | 10:48 AM
An EX MC and brake booster will work if you use a proportioning valve from the integra. However, even if u get the integra proportioning valve w/o the MC and BB it still will not work properly. Get the proportioning valve off a 93 integra. I THINK (but i'm not sure) that a MC and BB from a 93 teggy should work. However YOU MUST GET A PROPORTIONING VALVE.
Old Jul 10, 2006 | 10:54 AM
campbuds's Avatar
what about brake lines though. I need it to all bolt right up to my current lines and the firewall of course.
ic892003
Feb 8, 2008 05:43 PM
sway2003
Dec 27, 2006 07:33 PM
Dogmeat
Feb 3, 2006 10:38 PM
StifflersMom
Nov 9, 2005 01:39 PM
jcclow
Jan 21, 2005 09:36 PM
