Misfire on Cy 2
Old May 4, 2019 | 05:36 AM
Keith Marretta's Avatar
Default Misfire on Cy 2
Hi there All:
I have a 2000 Civic EX 4 door with 1.6 engine. While driving down the interstate the other day , I heard a slight noise followed by decrease in power. within seconds, the check engine light started flashing. After pulling over to see if I was leaking any fluids, or if anything was obviously wrong, I drove to Advance Auto and checked the computer. There where a few codes, but the only one that reset after clearing the computer was a misfire on cyl 2.
I have replaced plugs and wires, flip flopped injectors on 1 and 2 and the problem stays on 2, cleaned slight corrosion off the rotor and cap, and put in a fuel filter. I seem to have spark at allI read somewhere that it could be low fuel pressure and was thinking of putting in a cheap "generic" to test this idea.
Any help would be greatly appreciated!
EDIT: How much damage (if any) might be caused by driving with this condition?
Also should add that I have had a bad muffler leak for months that I have avoided. Could this have contributed at all to a misfire?
Thanks.
Old May 4, 2019 | 09:35 AM
Default Update/EDIT
I went ahead and put the fuel pump in with no improvement. It was super simple to put in, but guess fuel pressure was not the issue.
I just bought an OTC/HEI Ignition Spark Tester, so will go back through my spark diagnostic with it.
Good info on this forum. I have been reading about all different issues and feel closer to my Civic already!
Keith M
Pigwatcher3
Mar 21, 2012 01:54 AM
blazz
Jun 4, 2009 02:23 PM
Civic V2
May 26, 2007 01:17 PM
ten2doyle102
Oct 17, 2005 10:16 AM
redcivic99
Aug 29, 2005 09:50 PM
