MisFiring Help
99 civic
Wife called today said check engine light is on and it's running rough Idles rough and rough while driving, never happened before and she said it just started today. OBD II codes P0301 Cylinder 1 misfire detected P0302 Cylinder 2 misfire detected P0303 Cylinder 3 misfire detected P0304 Cylinder 4 misfire detected P0300 Random/Mustiple misfire detected P1399 Manufacturer Contrl Ignition System or misfire distributor cap problem ? Any help would be appreciated. Leroy |
RE: MisFiring Help
sound like wires or distributor, it could also be your ignition output module. replace the distributor. check to see if the distributor gets excessivley hot while the key is in the "on" position. if it does, then replace the dizzy.
good luck |
RE: MisFiring Help
Not gonna be wires b/c there is a pretty low chance that all four wires will go bad at once. Are you sure the last code is P1399? B/C i can't find the code in the service manual or online. I would think that the ignition coil could be a prob since it creates a spark. THe dist transfers the spark to the plugs.
RE: MisFiring Help
the last code was the P1399 and "Manufacturer Contrl Ignition System or misfire" was what my Actron OBDII sheet said.
thanks for the replies. I'm going to check the distr, but I've never danced with the ignition output, is it a pain ? or easy money to get too. Thanks again Leroy |
RE: MisFiring Help
I replaced the cap and rotor and fired it up. It does not seem as rough, but the engine is still vibrating. I checked the codes and now there is only one (without driving it)
P1399 Manufacturer Contrl Ignition System or misfire The old cap and rotor did need to be replaced. I saw you guys suggested the ignition coil or ignition output module. Same things ? or diff......hard to check ? let me know thanks again. leroy |
RE: MisFiring Help
#4 plug wire was cracked by the plug , causing havoc. Replaced all four and it's all fine .
Thanks for responses. Leroy |
RE: MisFiring Help
no problem, glad to help
