My Civic wont start Please Help
I have a 1995 honda civic that will crank over but will not fire and no fuel out of the fuel filter.The motor is a 1.5 sohc non vtec.
I change the main relay and no luck.I drove it to the gas station then back home and now doesnt fire or fuel it cranks though.I disconnected the battery then reconnected it nothing all fuses that i know of are good.Any suggestions or similar experiences????? |
RE: My Civic wont start Please Help
have you tryed replacing the fuel filter they are pretty cheap try that maybe it is glogged pretty bad
could it be a pump as well?
try to check voltage AT the fuel pump wire...if present its the fuel pump, if not, it's the ECU
your coil is prolly gone.
ORIGINAL: joey your coil is prolly gone. |
Spray some carb cleaner through the Throttle Body. That way you can be absolutly sure its a fuel problem. Spray the carb cleaner into theh throttle (open throttle plate, spary, close throttle plate) then crank the car, if there is no fuel it should start and then die. Also, to rule out the injectors, you can get this little tool taht will light up every time the injector fires when u point it.
ORIGINAL: nic95civic I have a 1995 honda civic that will crank over but will not fire and no fuel out of the fuel filter.The motor is a 1.5 sohc non vtec. I change the main relay and no luck.I drove it to the gas station then back home and now doesnt fire or fuel it cranks though.I disconnected the battery then reconnected it nothing all fuses that i know of are good.Any suggestions or similar experiences????? |
Im with Kolhoznik on this one, i think its the ECU, thats the first thing that would explain no fuel AND no fire.
I think its still worth checking voltage at the pump...could be two separate problems. Although very likely it is the ECU...if I knew how to check it...
try swapping ECUs with a friend and see if that fixes it:-D |
