My headlight works on high beam but not on normal beam
Old Dec 31, 2012 | 10:07 AM
blackseries99's Avatar
Default My headlight works on high beam but not on normal beam
The driver side(98 Civic) headlight doesnt work in normal beam. Blinker and high works.
The other headlight works just fine.
So whats wrong? Switch, fuse, blown bulb?
Thanks
Old Dec 31, 2012 | 10:47 AM
Check your fuses first.
Old Jan 1, 2013 | 08:21 AM
Most likely the bulb. Always suspect the bulb first. Pull it out and look at the filament. Headlight bulbs used in that model have two filaments, one for high and one for low, so it is possible (and likely) for only one beam to work. If one filament is in pieces loose in the bulb, replace bulb.
Old Jan 3, 2013 | 12:14 PM
danomatic93's Avatar
June 2010 ROTM
With enough use the Combination Switch (headlight switch) can fail internally. The plastic parts inside fatige and break.
For reference: https://www.hondacivicforum.com/foru...-switch-74275/
Old Jan 3, 2013 | 12:27 PM
Micky77's Avatar
Could be a cold solder joint on the module below the dash. Under the driver side there should be a grey box. Take it out, take it apart and look at the solder joints. A few may have some small cracks. Heat it up and drop a little more solder on them.
At least that was my problem.
chloiebear21
Dec 24, 2012 11:46 PM
Hondacipher
May 19, 2012 12:43 PM
vodevil
Jun 17, 2008 07:52 PM
gormac
Jul 24, 2007 04:29 AM
liliechen
Dec 25, 2005 11:15 AM
