MYSTERY PART IN 99 CIVIC (sensor of some kind)??!? PLEASE HELP!!!
Trying to find a very specific part. The guy at the honda dealership said its called an Idle sensor, but I can't find it anywhere on the net. It's attached to the Throttle body but that's about all i know.
Can someone tell me what this part is exactly and where I might find it? driving me nuts and my car is running less smooth !
I have a 1999 Honda Civic EX L4 1.6L
if you cant see the pictures visit them at these links:
http://flic.kr/p/aF3crZ
http://flic.kr/p/aF3crT
http://flic.kr/p/aF3crK
http://flic.kr/p/aF3cs4
http://flic.kr/p/aF3cs8
You have circled the plug for the throttle position sensor, commonly called the "TPS". The sensor itself is the black part secured to the back of the throttle body with breakaway screws.
There's no such thing as the "idle sensor". It appears you have an automatic EX, where there is the idle air control valve on the bottom of the throttle body. If the only problem is inconsistent idling, it should be removed and cleaned. Cleaning usually gets it working again, replacement is seldom needed.
If u think I should replace the plug for the TPS, where might I buy those plugs? (it has been very hard to find them so far. TPS sensor I found no problem).
Are u referring to cleaning the TPS sensor, the plug, or the idle control valve ?
if the TPS plug is cracked, you will have to source one from a junk yard. you can de-pin the plug, and re-pin a good plug onto it. there are little plastic tabs that hold the pins in place.
the TPS plug can be from basically any honda. just go cut one off at an autowrecker.
kser413
Aug 29, 2012 03:30 PM
halfpower
Mar 22, 2009 12:28 AM
Braidon5407
Jan 17, 2008 05:35 AM
Colby Day
13
Oct 1, 2006 10:10 PM
