need help for brake squealing noise
what happened to all the humanity in your town? Did they all leave, or something more sinister??j/k I know it was a typo, but it was kinda funny...anyway, I really think you have the same problem as I do - hard pads on softer rotors. I know it is so annoying, but I am just dealing with mine until I rebuild the entire setup.
Mike
Thanks anyway!
B. L.
some thoughts...
1) is it the spring steel tab that is there to warn when the pads are worn?
2) The pad is slightly loose in the caliper, it should fit quite snugly. Brake squeal is rapid vibration of the brake pad. Adjust (bend) the shim until a tight fit is achieved. If need be replace the shim or whack the pad base with a hammer to peen it larger and file it back to a good snug fit. That should fix 90% of squealing. It works. I hunted all over the net to determine that, many many stories of folks taking their car time after time to the dealer and not getting it fixed. Lots of people saying they would never buy another honda ever due to brake squeal. It is caused by the brake pad rattling around in the caliper, adjust the fit and it will go away. The clue is brake squeal when the brakes are lightly applied. Under light load the pad is free to rattle, stomp on the brakes and is goes away because it is unable to move about when tightly clamped to the disc.
3) If it's drums, lube the rub points, check the hold-down springs, sometimes shoe replacement will fix it, I've seen new shoes fix it. Some shoes will squeal for no obvious reason.
some thoughts...
2)It is possible, since both pad do not touch the disc at the same time could result the same problem. Thanks for the tips, that is great help regardless whatever my case is.
3) Unlikely, but I will keep your tip in mind.
some thoughts...
anyways, to answer the earlier question, i doubt any squeal would be humidity dependent but if that is possible, then it won't be due to the squealer since that will squeal no matter what, and from listening to your problem, it probably is either vibration against the shims/caliper or improper bed in.
FYI the shims I'm referring to are the ones that are between the edge of the pad and the caliper. These are the shims that fit between the pad "ears" and the grooves in the caliper.
In the honda service manual they are called retainers. in any event, the idea is to bend them to enhance their spring effect to dissuade the pad from moving around.
I had an accord come to me with a wicked brake squeal, after plenty of noodling about on the net I came across this idea and it worked for that car. One pad could easily be moved around by hand when everything was assembled, adjusted the retainer shim, that made it much harder to jiggle and the squeal ceased. Of course the question then is what do you charge for a 5 minute repair that takes a couple hours to figure out that you should have known about in the first place? $20 and hope they come back when a bigger repair is needed.........
oh wow, i'm feel stupid for never thinking about bending the shims back out against the pad. whenever i encounter worn shims i always buy new ones or just lube the **** out of it lol.
