NEED HELP!!!!!Car won't start after swap
I recently swapped in a d16 into my eg hatch,and the engine turn over but not starting, spark and fuel is a check, and it will only start when Iuse starting fuel.......can anyonehelp me out with the problem......need help asap....thanks in advance
RE: NEED HELP!!!!!Car won't start after swap
Is your ECU setting any codes? Are you sure all sensors got plugged back in correctly and are functional?
Also, be very careful about using starting fluid. I know of one guy who used a little and couldn't start up, so he sprayed a little more in, same result, sprayed more in and tried again and BOOM! Big internal explosion, bent rods and all kinds of other damage. I recommed staying away from it. |
When you say that you checked the fuel, what exactly did you do? The symptoms fit with a failure of the fuel system to deliver fuel to the cylinders.
You may want to check the fuel pressure and whether the fuel injectors are working. |
I was thinking about the fuel problem too, but I changed teh whole fuel rail with injector with from a working motor...but the same problem still occur....I just notice another thing, everytime when I try to crank the motor, there will be a small spark from the transmission ground....pls help..I'm getting desperate....
Thanks |
You should check whether your engine ground wires are tightly connected and not corroded.
With respect to the fuel system problem, the next step is to test your main relay and fuel pump and also possibly replace the fuel filter (see pictures). http://img238.imageshack.us/img238/4...ure0448xl6.jpg http://img238.imageshack.us/img238/6...ure0447ps5.jpg http://img238.imageshack.us/img238/4...ure0446fe4.jpg |
No wires should be sparking. Also check the little ground wires on the thermostat housing. Very easy to forget those.
why is the diagram's # outlet different from the # listed on the relay...but I dont' understand why it would be the problem because the car was running when I put that out.....
Thanks |
ORIGINAL: free_2_one why is the diagram's # outlet different from the # listed on the relay... |
