Need help no heat!
Old Dec 5, 2007 | 03:34 PM
mr2turboo91's Avatar
Default Need help no heat!
hi i have a 94 civic with a b16 a and i have no heat, just blows cold air. I replaced and checked.
-replaced t stat
-blew out heater core(flows threw fine )
-heater valve is open
-both in and out heater core lines are hott.
-new water pump
i dont no what else to check lower rad hose is cold i was told thats the way it is. please help im at a dead end rite now. thank you
Old Dec 5, 2007 | 03:50 PM
Default RE: Need help no heat!
The picture may suggest additional heater components to troubleshoot.
[IMG]local://upfiles/25538/442733801218412B94B6657E59D2DC9D.jpg[/IMG]
Old Dec 5, 2007 | 03:55 PM
AOL.COM's Avatar
if both heater hoses are hot , i would say you might have a stuck or broken blend / recirculation door under the dash
Old Dec 5, 2007 | 06:08 PM
what is your temp gauge on ur dash showing example: cold, balrely above cold, in the middle,etc.
ive had a few hondas where if it was real cold out side my motor would not heat up and blow heat. so i would put a peice of cardboard in front of the radiator to block the cold. and it worked great. or it could be ur climate control under ur dash
mck519138
Feb 25, 2010 11:42 AM
jyn
Mar 25, 2009 04:04 PM
Tinkerbell_too
Jan 24, 2009 06:39 PM
boomer3
Dec 11, 2008 04:00 AM
Scavenger32
Jun 29, 2007 09:56 AM
