Need Help Removing Center Dash Panel in 07 Civic
Old Jun 29, 2007 | 10:01 AM
shunut's Avatar
Default Need Help Removing Center Dash Panel in 07 Civic
Like the title says I need help removing the center dash panel in a 07 Civic. The panel that has the climate and stereo controls. I've had my car in at Honda 3 times now for a "rattling" in the air vent and they still can't get it fixed. I said there is something in the vent but they keep insisting it is the vent itself. They have replaced the vents twice now, which have made no difference. They also had to replace the airbag panel on the passenger side because they scratched it all up replacing the vents last time. I'm fairly mechanically incline so I figure I can probably fix it better than they can. However I want to make sure I take the panel off correctly so I don't break anything. Usually I would refer to a Clinton's or Haynes' but there isn't one available for my car yet.
So if someone could give me a short "How To" on removing that panel I would really appreciate it.
Thanks.
Old Jun 29, 2007 | 10:40 AM
IMissMyCivic's Avatar
Default RE: Need Help Removing Center Dash Panel in 07 Civic
ok under your a/c controls there should be a center pocket, remove the coving piece and remove 2 bolts from the bottom, then the whole bracket should come off with a/c controls and radio still attached,(should be held in withclips)make sure to have your radio lock out code before you unplug ur radio.
Old Jun 29, 2007 | 01:25 PM
shunut's Avatar
Thanks I'll go give that a try right now.
joeD2J
Apr 3, 2011 02:18 AM
Zarath
Jan 9, 2009 07:27 PM
IMPORTEDCONCEPTZ
Dec 10, 2006 09:46 PM
count26
Apr 16, 2006 08:48 PM
PredatorCoder
Aug 15, 2005 05:43 PM
