No brake light
Old Nov 12, 2008 | 07:25 AM
Jaynik's Avatar
Default No brake light
Running lights on, brake lights do not work at all, even the one in the window.
Not fuse, not pedal switch, not bulbs. What is left?
6th gen SI Coupe
Old Nov 12, 2008 | 07:43 AM
FlipHKD720's Avatar
relays? There are a couple under the dash, and there are also some under the hood
Old Nov 12, 2008 | 07:50 AM
Is fuse 52 under the hood blown? Do you have battery voltage at the WHT/GRN wire of the brake pedal switch?
Old Nov 12, 2008 | 08:12 AM
Jaynik's Avatar
Default well
by testing for voltage and the process of elimination I have narrowed it down to either a break in the wire between the pedal switch and the split for the 5 different brake lights or a problem with what the wiring diagram refers to as "Junction Connector 3442(right kick panel)"
anyone know exactly where that connector is and what it looks like. Maybe a picture if its convienent?
Old Nov 12, 2008 | 08:16 AM
Edit: I see you've checked some more. So my one useful suggestion would pertain to a hatchback:
On a hatchback model, the wires going to the lights on the hatch can break where they flex every time the hatch is opened.
Old Nov 12, 2008 | 08:31 AM
Jaynik's Avatar
Default nay
not a hatchback. That will be handy to know for when it does fail on my other civic(which I'm sure it will)
Old Nov 12, 2008 | 08:44 AM
The connector is C442. G601 is also of interest. The three diagrams below should help with further troubleshooting.
Old Nov 12, 2008 | 09:29 AM
inthezoneac's Avatar
do your blinkers and hazards work? I know one time I was messing with my radio, forgot to hook the hazards back up and no brake lights, blinkers, or hazard lights worked.
Old Nov 12, 2008 | 10:33 AM
Jaynik's Avatar
Default praise
ron your a GOD. Were those diagrams in the shop manual? I didn't see them!
Old Nov 12, 2008 | 10:42 AM
Yeah, you can find those diagrams and others in the two electrical chapters of the 96-00 manual.
