No BreakLights =[
Old Sep 10, 2007 | 10:35 AM
cooper1's Avatar
Default No BreakLights =[
I have a 2000 civic si..
the other day i was checking my blinkers and breaklights and all that stuff..
well i noticed i didn't have any breaklights..but i do have taillights..i checked all my fuses none are blown, any ideas?? im fresh out..
thanks..
Old Sep 10, 2007 | 11:45 AM
Default RE: No BreakLights =[
Actually it is possible for all the brake light bulbs to be burnt out, especially if you haven't checked in a while. The same bulb does the brake lights and tail lights but there are two independent filaments in the bulb so one can be burnt out. After ruling out the bulbs, find the brake light switch at the top of the brake pedal assembly and unplug it. If you jumper the wires in the plug the brake lights should come on.
Old Sep 10, 2007 | 11:50 AM
dito what he said... could be bad bulbs check those first THEN if those are fine i would check the brake switch. it could have gone bad.
Old Sep 10, 2007 | 07:12 PM
cooper1's Avatar
alright guys thanks alot..i appreciate it..
i'll check it out tomarrow..and let you know how it goes..
