no check engine light on but having engine issues...
sometimes when I try to start the car it feels like it wants to give out but then turns... and sometimes when I'm on idle for a few minutes the car starts to shake weirdly and feel like it wants to shut off but doesn't....
More info please.
Check your starter? Im not sure about that part, but my car would start idling violently also. And it turned out i had a bad plug wore. After shanging that, it ran perfect. Also check your spark plugs. Make sure all connections are tight. Lastly check your distributor cap. If it looks worn then clean it down or replace it. Hope this helps.
Do a cel test, maybe the bulb is out. You could be throwing codes without knowing.
Could be many things: 1Spark plugs 2Spark plug wires 3Dizzy cap 4Fuel filter 5O2 sensors 6air filter 7IACV |
If you take your car to the dealer to have them diagnose it. And if it is the main computer you're looking at easy 800 to 1000 bucks. The main computer is something that doesn't go bad very often. It's very rare. Not to mention the amount of money they're going to charge you just to figure out what's going on with your car. What you should do is take it to Autozone if there is one in your area don't take it to this mr. Tire place. Because the fact that they charged $110 just to pull the code sounds to me like there a scam. Anyways take it to Autozone have them pull the code for free and then once you have that code. You can post it on this forum and hopefully some pretty knowledgeable guys on this forum can help you out. But also do your part type in the code on Google to see what comes up.
Originally Posted by miguel11691
(Post 771515)
