no power
Old Jan 6, 2010 | 07:48 PM
Honda93's Avatar
Question no power
I just recently changed my head gasket and the intake and exhaust gaskets, after i put it together it ran good except for the timing was a little off. I thought i had gotten it right or at least close, but now i when i drive it i have no power. I had to drive it to and from work in third gear and it did not sound good. Any help would be appreciated. I am going to sell it or at least try to, so if anybody knows anybody in or around the Portland Oregon area let me know.
Old Jan 7, 2010 | 04:28 AM
Disconnect the fuel injectors one at a time to make sure all 4 cylinders are working.
Check timing with a timing light (you must install the ECU test jumper). Distributor should be near the center of adjusting range when properly timed. If you have to go to the end to get proper spark timing, the timing belt is on wrong.
Old Jan 7, 2010 | 06:46 AM
You must set the mechanical timing perfectly with both the cam and crank synchronized at TDC1:
Old Jan 8, 2010 | 05:24 PM
Largen's Avatar
I would say... Ron's got this one down
prodigyskate5
Jan 21, 2009 01:13 PM
XNXIXTXRXOX
Aug 22, 2008 10:11 AM
civic_66
Nov 20, 2006 02:44 PM
Kturner
Sep 25, 2006 08:38 AM
e2k4
Sep 11, 2006 07:10 PM
