no vtec
Old Feb 23, 2005 | 03:57 PM
blackeyes's Avatar
Default no vtec
only when i first turn my car on in the morning i vtec does not change over but after it warms up it is fine. i dont have a knock sensor but can that be the problem?
Old Feb 23, 2005 | 05:24 PM
Blackhatch124's Avatar
Default RE: no vtec
until the car warms up you wont have VTEC its the same for everyone who has it
Old Feb 23, 2005 | 07:16 PM
blackeyes's Avatar
Default RE: no vtec
just a question, thanks.
Old Feb 23, 2005 | 08:41 PM
sacicons's Avatar
Default RE: no vtec
yeah, its a safety design. it wont use the changeover unless its warmed enough to go into open loop and use the info from the sensors. (i may have open/closed mixed up)
Old Feb 23, 2005 | 08:53 PM
sugerbear008's Avatar
Default RE: no vtec
i don't know if my vtec is working at all how do you tell when it is.
Old Feb 23, 2005 | 09:42 PM
XCM828's Avatar
Default RE: no vtec
The sound coming from the engine should change when it kicks in. It should become significantly louder on DOHC engines, but it's sometimes hard to tell on SOHC engines.
Old Feb 23, 2005 | 09:44 PM
Default RE: no vtec
i have the sohc so i guess i'll just play like i hear it or just hum.
Old Feb 23, 2005 | 09:47 PM
XCM828's Avatar
Default RE: no vtec
You can definetly hear it if you know what you are listening for. It should kick on between 5k and 6k rpm. The sound is kind of hard to explain. It sounds more.....oh, how do I put this.....mechanical?
Old Feb 23, 2005 | 09:49 PM
Default RE: no vtec
sounds like the manifold is putting out more air or something.
Old Feb 23, 2005 | 10:28 PM
sacicons's Avatar
Default RE: no vtec
something. but its a lot easier to hear with an intake
