Noise coming from engine, squeaking(video inside)
Old Nov 8, 2012 | 03:22 PM
AndrewH.'s Avatar
Default Noise coming from engine, squeaking(video inside)
Old Nov 8, 2012 | 05:50 PM
conceptualpolymer's Avatar
Do you have a mechanic's stethescope? That may help to isolate the source of the noise.
Old Nov 9, 2012 | 04:46 AM
Is the power steering reservoir full? Sounds like the pump running dry. (If you need to add some, use only Honda fluid or some that is specifically labeled as suitable for Honda, not generic power steering fluid).
If it's not that, take all the belts off and spin the alternator, etc. by hand. It should be apparent which one is making noise. If it's not one of those, start the engine with the belts off, if still noisy it is something related to the timing belt.
Old Nov 9, 2012 | 05:23 AM
Zoz's Avatar
Zoz
Power steering pump wheel looks like if it was loose or something, it is moving sideways and up/down. Or is it just the video?
Old Nov 9, 2012 | 09:15 AM
AndrewH.'s Avatar
yeah it was moving sideways, someone else said it was the powersteering pulley that was lose. imma tighten it and see if thats it. then do the alt, and yeah power steering pump is full.
warsias
Oct 25, 2009 10:20 AM
havok_wesley
Mar 16, 2009 04:55 PM
havok_wesley
Jul 6, 2008 08:07 AM
MetAJJicA
Aug 22, 2007 02:12 PM
Forty04
Jul 11, 2005 08:24 AM
