O2 Sensor
Old Oct 16, 2010 | 09:46 PM
KingDakota12's Avatar
Default O2 Sensor
Ok so Im going to be changing my o2 sensor since it is the source of my check engine light, Im getting it online since it's almost $40+ cheaper than Autozone.
Its the before cat. converter main sensor, but online they sell a 3,4, and 1 wire o2 sensor, which one do I need or would fit best?
Links would help, thanks!
Old Oct 17, 2010 | 02:48 AM
Bump for an answer, I'm in the same boat lol.
Old Oct 17, 2010 | 06:34 AM
Cant you look at the OEM one that is currently installed? I think it is a 4 wire plug.
Old Oct 17, 2010 | 06:55 AM
if it's a 6th generation non-VTEC, check for cracked manifold first. The HX requires a different (expensive) sensor-- I don't think generic ones will work.
Otherwise if that's the only detail you have, it's a 4 wire type.
addiction2bass
Aug 14, 2008 09:53 PM
fglaustin
Mar 27, 2008 08:29 PM
vtec02
May 9, 2007 05:17 AM
00sithrottle
May 12, 2005 10:25 AM
