OBD code P1457 - EVAP by pass
Old Dec 13, 2007 | 04:48 AM
rkzimmerman's Avatar
Default OBD code P1457 - EVAP by pass
My 2004 Civic check engine light illuminated - OBD code is P1457
The car was taken to my mechanics and they replaced the EVAP bypass vlave and fuel tank cap.
The check engine light came back on at about 1/2 tank - other symptoms are: Car is difficult to start and will not idle after fuel tank cap is removed, car re-fueled, and cap replaced. The Car will start and operate normally after being driven a block or two.
Does anybody have any idea what is wrong?
Old Dec 13, 2007 | 05:12 AM
Default RE: OBD code P1457 - EVAP by pass
Several other components of the EVAP system can throw this code, for example a faulty Canister Purge Valve, Canister Vent Shut Valve, Vapor line, Circuit, or Canister.
Return your car to your mechanic to have these other EVAP components tested.
brandonv
Dec 26, 2012 11:02 AM
cobr888
Oct 14, 2012 11:17 AM
nameshift
Jan 30, 2011 09:33 AM
SoCaL.rider
37
Nov 26, 2007 10:28 AM
WHISP63
Oct 24, 2006 11:04 AM
