Oh, My Civic....
Old Jan 25, 2007 | 10:04 AM
helloheather03's Avatar
Default Oh, My Civic....
Ok...I need some help here. I have a 1991 Honda Civic Hatchback Si. It has the 1.6 L engine 16 valve. SOHC The engine is a D16A6. I need to find out if it came out stock with a power steering pump. Does anyone know about this? Also, in order to get the computer module for it, I need to find out the specs on the fuel injectors. Can anyone tell me how to do this? Thanks for reading!
Old Jan 25, 2007 | 10:14 PM
Impreza WRX's Avatar
Default RE: Oh, My Civic....
Look at your belt system. There should be: 1: Alternator 2: A/C Compressor 3: Power Steering Pump
Follow the hose from your power steering fluid filler or from your steering rack. If you have no fluid filler / hose or there are two (or one w/o a/c) accessory pulleys, you have no power steering. Honda Civics have all the necessary stuff built into the engine, with only the alternator on the accessory belt.
