Oil burning - Still scratching my head..
I know, repeat post. But this has still got me scratching my head.
I can live with checking the oil level, but I need to understand the why or how I'm burning it.
New valve seals, 180psi on comression test (dry) all cylinders, car runs great and averages 35-40mpg.
But I'm burning oil. Some trips I use next to none, others I use damn near a half quart in 100 miles! Doesn't seem to be any rhyme or reason to the madness.
Is it the oil control rings, or the new valve seals? Or am I missing something obvious here?
- On acceleration, after around 4000rpm and higher RPM's I see a blue haze in my rear view.
- There's a big hill by my house with a stop sign at the bottom. No matter how lightly you accelerate from the stop sign, it always produces a nice blue cloud.
- Breather tube is clean, new PCV valve. Installed a oil seperator in the PCV line. Nothing excessive collecting in there.
- Usage seems to be lesser with heavier weight oil.
The plugs are all clean looking, no residue and a nice healthy color.
Didn't try the leakdown test because I got what seemed to be pretty good results on the compression test.
Soon as this rain gives in, I'll rent the tester and give it a try.
Still trying to track down the tool. I thought autozone rented them, but they don't. Nobody I know has one either.
A buddy of mine insists it's the oil control rings. Said it's pretty common on Honda's for them to leak.
I'm gonna get some fittings and regulator from lowes tonight and try to make my own tester..
[edit]
Here's the plans I'm basing my leakdown tester on. Instead of gutting a spark plug, I'm using the hose and fittings from my compression tester.
http://www.motorcycleproject.com/mot.../leakdown.html
Well, I don't know how accuracte my tester is but I'm seeing roughly 15% across all four cylinders.
On all 4 cylinders I can hear the leakage going into the crankcase.
I redid my compression test while I was at it and got 178-180 across all four again..
Here are the plugs. Sorry for the low quality, I didn't realize my camera lens was smudged until I was done and back inside. :/
also is that one plug in the same pics and do they all look lik that? if so are they lik that after cupple days of driving if so then the rings have to be fine wat kinda smok is it a darker black lightish black/grey or a blueish
